Water exposure to module in soft-top
I’d been rolling for a few weeks without my soft-top back panels in. Rain or shine, I’d just wipe things down. I’d already removed the drain plug from the scissor jack compartment. Didn’t think much of it.
Until I got this error [repeatedly]:
Turns out the back isn’t as water resistant as I’d imaged. Royal Oak Ford was kind enough to code-confirm, and point out (to them) the obvious: keep water out of the back cargo area.
Issue did clear up on its own after a few days.
Might help someone else out.
If you (or anyone) really ever needs a code confirm, I can just hook up my laptop so no one needs to spend the $100 or whatever they charge usually. Or if you have Ford Pass I can look it up in PTS with your VIN.
That’s good to know! I have an obd2 scanner I can use with my phone, but sometimes it would be nice to see the output and issues on a laptop.
Bummer on the water intrusion Jake :face_with_diagonal_mouth:
Thankfully they didn’t charge anything.
I have the whole forscan / laptop setup, but honestly didn’t think to hook it up.
Good idea.
